It would be highly unusual for a sealed bottom bracket to go bad on a relatively new bike. If it doesn't move a lot and you hear a "clunk" when you grab the arms and forcefully move them laterally, that is an indication that the cartridge was not tightened enough when it left the factory. You would need to remove both crank arms, loosen the left side support cup very slightly, tighten the cartridge on the right side fully (it is left hand threaded) to approximately 40 ft.lbs., and retighten the other side.
