keithb
On my Super Commuter 8S, I needed a rear rack-bag capable of carrying two extra Bosch batteries, tools, accessories, snacks, etc. The minuscule stock SC8 rack essentially limits rear-bag options to panniers.
My solution was to buy a Topeak QR Beam seat post rack (Link Removed - No Longer Exists). As delivered, the problem with the Topeak QR Beam is its cantilever design. This limits the useful weight limit and makes it susceptible to lateral movement while riding. To fix this issue, I fabricated two stabilizing struts out of thin-wall 4130 steel tubing and connected the racks together with 5/16 inch adel clamps. I have ridden with this setup on approximately a dozen long rides with no major issues. It works very well. Even with the weight of two extra batteries in the bag, it is all rock solid. The bag is a Topeak MTX Trunk Bag DX (Link Removed - No Longer Exists). The bag can be attached and removed from the bike in seconds with the built-in quick release. The bag's top is expandable and it also has two side pockets for wallets, keys, tools, etc. It's a well thought out design and very convenient. Only modification so far is that I will be adding a thin steel cable with a quick connect clip to prevent the bag from inadvertently sliding off the rack from the rear (this happened once after going over an unexpected large speed-bump at a too high speed).
Photos are below. Later this month I will be powder coating to flat-black all of the bare Topeak aluminum and the bare steel struts.
Thanks to Luv2ride on this forum for inspiring this!
