hi all!
i got this bike with the intention of commuting with it. i originally was looking at a 2018 giant road-e+ 1, but long story short, i got the prior (2017) model with the 4 power settings (off, eco, normal, power). turns out, giant did a mid-year remodel update. so far, i've ridden the 24 mile one-way route to work twice, and expect to ride it MWF. i've been doing joy rides, so it has 332 miles total.
a little about me: i'm 29 and in decent cycling shape. i wanted to give a different perspective.
i hope that e-bikes catch on!
so far i have added:
1. large revelate ranger bag
2. shimano a-530 pedals. these provide a platform for regular shoes and SPD clips for your shoes.
3. 35mm schwalbe kojak kevlar bead tires
3. my monkey lights front light. i may need to get some new AA rechargeable batteries, because the current ones are from a camera back in the day and no longer hold charge well!
4. salsa rack-lock 35mm seat collar (you can run rack stays to this). i have yet to install a rack but have a Tubus laying around.
what i plan to add:
1. sks bluemels fenders (have these, working on getting bolts/spacers to install)
2. light and motion nip-n-tuck lights (these are on order from Goride Bicycles out of Redwood City-same place i got the bike!)
3. racktime vida panniers
some issues i wanted to share, in no particular order. none of these are deal-breakers to me, i still love the bike for its purpose:
1. display is slow to switch between settings.
2. front fork caliper mount is IS standard. this requires an adaptor, and personally, i hate things with adaptors/more interfaces.
3. schwalbe durano tires are wire bead. this seems sort of cheap given the $4k MSRP price.
4. i descended kings mountain road and the rotors were hot to the touch on a cool day and squealing at the bottom. i may get some 180mm shimano sm-rt86 rotors to dissipate the heat better. i don't think that size is recommended, but being 200lbs dry, with a 45+ pound bike, plus gear, i beg to differ.
5. the walk button is hard to press. i was trying to use it when i was out of juice on a steep hill, but the little bugger is very hard to depress and keep depressed. almost renders it useless. guess i should do some thumb exercises?
6. the ride of the bike is rough. this is very subjective, but i came off of a trek domane with 25mm tires, inflated to 100psi, which has a isospeed coupler in the rear. the isospeed basically dampens some of the shock. i think large/higher volume tires, with lower pressures is the easiest way to solve the problem without introducing too much $ or complexity or inefficiences. this was my intent with the '35mm' schwalbe kojaks, but they only measure 31-31.5mm @70psi, whereas the stock schwalbe duranos measure 29.5-30.5mm, just a 1mm difference.
7. you need to clear the 'max speed' setting separately from the other settings if you want to track the new ride. kind of like the walk button, it's just annoying.
all that said, it's a lot of fun! feel free to ask me any questions if you are considering getting this specific bike or an e-bike in general. i appreciate all the resources that this site has offered me and want to give back some.
what i plan to add:
