steve marino
This may not make any sense to anyone here, but that's OK, it doesn't make much sense to me either. I've monitored this repeatedly, and if I go easy on the throttle and pedal a lot at slow speeds, I have less batter power left than if I go fast and use the throttle a lot. Probably a dozen times I've measured this on my daily coffee-in-the-park run of 12 miles round trip, and it's always the same outcome, assuming wind isn't a factor.
The only two things I can think of that might account for this is, A- I get where I'm going much faster if I go fast, so the battery is used less time than on the slow runs, and B- when the bike is traveling fast, I have a good cadence going w/ the pedals, so even though the throttle is open it's not really being used much, my legs and the bike's momentum are more in play.
Now this is using the bike the way one would normally use it. The battery usage could be almost zero if I pedaled 90% of the time and used the throttle the remaining 10%, but this is riding the bike like most anyone would ride it. It's been checked w/ a volt/ohm meter as well as with the LED readout on the handlebars too.
