Bruce Arnold
We've had a couple of posts lately from guys wondering if there was something going on with their motor because of the sounds it makes. @Reid gave a good description in one of the threads of how they work and why they might make a different noise at times. When my motor sounds louder than normal, I coast until the motor cuts off and then start pedaling again. It might take 1 or 2 tries -- occasionally more -- but the gears will find the sweet spot again and it gets much quieter.
With just under 1,300 miles on my CCS, this seems to happen more now than at first.
A pessimist or a worrier might think that spelled impending doom. Given what we know about hub motors, I've concluded that it is just a question of the motor getting worn-in.
Here's an example from another hobby of mine. When you first buy a mechanical watch, you will get a lot of variance in whether it gains or loses time. Sometimes it will swing pretty far in one direction or another. It might be gaining 4 seconds a day, and suddenly start to lose 20 seconds a day. After 1-3 months, when the mechanism has worn in, it will settle into a fairly predictable pattern. There are still some variations based on temperature, what position you leave it in at night, even the amount or kind of activity you have during the day. But those variations will be within a predictable range, not swinging from here to there as before.
Gears is gears, whether tiny watch gears or larger hub motor gears. In the case of our hub motors, because of the kind of work they do, we are able to hear differences in the sound the motor makes. It changes some over time. This is neither a feature nor a bug. It just is.
Kinda thinking out loud here. I could be way wrong.
