Hi,
Confused regarding C7 display on my Moscow Plus. With a fully charged battery, I rode approximately 30 km with voltage indicating above 50. Basically flat terrain. All 4 battery lights were still on, as was the 5 bars in the display.
On my ride home, I climb a fairly steep hill for about 1 km. On the steepest section, with my PAS at 5 (6 is max) and my front derailer in the middle ring (3 rings in all) and my rear derailer set at gear 2 (out of 8), my max speed on the steepest section (a distance of approximately 250 feet), is about 10kph. Of course, I am pedalling as well (and praying my battery does not die!!).
I noticed the volts had dropped to about 45-46 (at that time, I had rode about 45 km). I heard a knocking sound from my rear hub, as if something was not right. Changing to a lower or higher PAS did not stop that knocking sound. Only stopped once I reached flatter ground. Power seemed much weaker. Must be a connection to the lower battery voltage.
When I completed my ride, covering 51 km, I was down to 2 lights on the battery. (Charging battery now).
Any suggestions would be appreciated re whether my experience is normal or not. Perhaps a battery issue? I have only 700 km on my bike.
Thanks everyone...most appreciated!
