Stefan Mikes
- Europe
- City
- Mazovia, Poland
I own two e-bikes, one with a hub motor and the other with a mid-drive one. When I was riding either of them at relatively warm weather, gentle breezes (and the terrain here is flat), I felt no real difference between them. The things have changed with the season of stiff winds interrupted with squalls.
Depending on the assistance level, the hub motor provides some support. You need to follow what the motor is doing by pedalling at the right gear until some resistance from bike can be felt. The controller also reads your cadence and adjusts the power accordingly until the equilibrium is achieved. It feels as if you needed to follow the motor with your pedalling. Now, if an adverse squall hits you, the bike slows down. As you instinctively maintain the equilibrium of forces, you pedal at slower cadence. Then, the controller thinks "Oh, this guy wants to ride slower!" The power to the motor is reduced and you are stalling. Unless you shift down and increase the cadence, so the controller can pump some more juice into the motor.
It is different with the mid-drive motor. It is the motor that follows your pedalling, and the torque sensor is there, in addition to the cadence sensor. In the case of a squall, you instinctively stamp on pedals harder. Instantly, the controller gives motor more power. So your bike won't slow down but would rather pierce through the wind as a hot rod cuts through thin ice.
It is similar while climbing. Provided you are in more or less proper gear, the mid-drive motor e-bike can climb at constant speed while the speed of the hub motor bike gradually drops down until the equilibrium is reached.
My observation is two different bikes, either with different motor type use energy differently on the same routes under the same weather conditions. The simplest explanation would be it costs you the battery energy to ride at constant speed regardless varying resistances during the trip. Hub drive motor does not support you as efficiently but uses less energy overall.
On my winter rides, my mid-drive e-bike has the range of approximately 80% of what the hub motor e-bike can provide, with similar battery capacity.
Your observations?
Your observations?
