eagamer80
Hi guys,
I had my bike on the garage since last december, which I stopped cycling due to the weather here in Sweden it gets nasty with all the snow, salt and gravel that there's on the road. That literally destroys all mechanical parts of the bike specially if you don't clean it after use. Anyway... the thing is that I came back to business and have notice now two symptoms which may be a problem.
1- M-ERR message when I boot up the battery on the bike. Motor no response. Or it may respond after changing to ECO mode and pedal a little.
2- Back wheel spinning by itself to max speed when I give a little push on the pedals (it literally goes on by itself unless I completely break the wheel).
The M-ERR message might dissapear if I turn off-on again, and after pedaling for a while.
When I boot without the ERR message the symptom 2 shows up (but it works, I can make my commute to work).
Bike out of warranty already. I've no idea where to check.
