On my way to work it just died , would not start back up. Checked all connections that I could see at 5:00 am they were fine, tried it again after hauling it home still nothing. I then plugged in the charger and bike and it ran fine. I had charged it the night before to 90% and was about 2 miles into my commute. I have taken it out just around town a few times trying to replicate the problem but it has ran fine. Just not confident enough in it for the work commute. I'll stick with the haibike and rad.
Had the same thing happen... BBS02. Contacted the dealer, BafangUSAdirect, and received a super prompt reply (1hour response). This was the fix they provided - worked!
Hi Jeff,
Sorry to hear that you are experiencing trouble with your kit! Thanks for sending us a message with detailed information regarding the problem. We really appreciate it.
It sounds like the issue is coming from the connection between the battery and the mount. Please follow these steps in order to (hopefully) remedy the issue:
1. Turn your whole system off and remove the battery.
2. Once the battery is removed try and turn on your Bafang motor with the power button (though the motor won't power on because there is no battery it should use any residual power in the system so it doesn't spark when you fix the connection).
3. Once this has been done, use a pair of pliers to tweak/ squeeze the two outside male prong connectors on your battery mount inwards to make sure that your battery has a good solid connection with the mount.
Please let us know if you have any questions.
We want to get you up and enjoying the ride ASAP!
Thanks!
Mari
BafangUSAdirect
