I lost one of the keys to remove the battery from my CCS frame. I think that the plastic top simply gave way under pressure and the key fell off the key chain. Not sure about that; good guess though. So having one key bothered me. If the same thing happened again, I'd be SOL as far as not being...
Misplaced your Aventon Original Sinch Ebike key? No problem. enter your battery lock number, & get a custom key set with two replacements. ✅ Over 1,000 authorized service dealers ✅ 2-year warranty ✅ Fast & free shipping over $100 ✅ Ride more. Be happy.
www.aventon.com
Pick the Pace 500 Reention edition and enter the number from your lock. They should be able to cut you one.
This is why I never use a lock/ignition key, etc,, unless I have at least one spare key at home. If I start with 2 and lose one, I immediately try to get a duplicate.
Honda spec HD75 will work but youll have to have key cutter manually cut the stop notch back about 3mm so tip will reach last wafer. can do with a file if they dont have manual key cutter. you can remove last wafer if they wont cut it manually. Just rotate and pull E-clip that retains cylinder once you take lock out with 2 screws next to battery locking lug.
