e_adventure
Hello, I am in the market for a new ebike that can handle a long and hilly daily commute to work. I've tested out a few bikes at my LBS, and was enjoying the mid-drive Bosch performance CX system and its climbing ability ((Link Removed - No Longer Exists)- a MTB setup, but I would convert it to more of a commuter); I was also interested in the Haibikes with the Yamaha motor but they may not be at the LBS for some time yet.
I've recently been turned on to another bike that I was wasn't originally considering, mostly because it was more than I was planning to spend: the OHM XU700 16. I've seen lots of positive reviews on this site for this bike, and it seems to be spec'd out for the long-haul. I may also have the opportunity to run the same Bionx 500W D-series system on a more retro-fit setup on a new crossover type bike like the Norco XFR3, for more than 1k less than the OHM (on a much lower spec'd bike to be sure... and as far as I'm aware, the retro-fit bionx motor can't be run as a 45km/hr speed pedelec, but I'm not totally certain this can't be changed/unlocked??). Any thoughts on these bikes? I should mention what my needs are...
I'm 36 and in relatively good shape, 5'7 and 150lbs. I've been riding bikes my whole life (MTB, road), and have been commuting to work on my bicycle for the past several years. I moved a while back- increasing my commuting distance, resulting in a much more difficult ride that I can only manage once or twice a week now (I also have a physical job so my energy is at a premium!). I would like to get back into the bicycle commute as much as possible (at least 4 times/week), as the car commute is wearing me down in other ways. Currently I ride an old bombproof steel triathlon frame in a commuter setup (riser bars, thumb shifters, wider 700c tires and a rear rack), about a total of 10km (plus a section on transit in the middle of the trip to cut it down from twice that distance), with long big hills on both ends.
My ideal situation would be able to ride all the way to work without the transit section, which means about 20km of riding each way. I wasn't originally thinking that I would eliminate the transit piece, though a powerful ebike makes the idea seem more reasonable (and fun!). While the Bosch CX setup climbed like a moutain goat, I found the bike geometry didn't feel totally right for a long daily commute. My budget was originally up to about $4k CAD (~$3k USD) for a commuter set up, so that led me to my initial choices. Given the possibility that I could avoid the transit piece (and save about $100-120/month) with a more powerful (and fast!) bike, I'm considering on upping my budget to make the OHM bike work.
Any thoughts/opinions on the OHM setup? Is it worth the $1k+ upgrade vs. the retrofit Norco with the same Bionx system? Any other suggestions on options or other bikes I should consider?
Thanks
Thanks
