Lights not working
Australia
Perth Western Australia
Hi I've recently had to replace the rear light on my Ebike, and it only lasted one day, and now the front light is also playing up, that lights on my LCD display are working, the motor is working, and PAS is also working
try the simple things first, loose bulb connection? loose wiring connector? check light wiring cables for damage, dirt or water somewhere in the wiring? have a close look at any soldered joints if you can. If everything else is working but the lights are failing, it points to an issue within the light wiring or wiring connectors.
The wiring has been checked externally, all connected
Update, after watching a few videos and a trip to the bike shop, I'm now thinking possible Mosfett failure, I'll know more on Friday, I've just tested the lights again, front light now working, I've called and advised the bike shop of the update, and what I think the issue is
