BigDaddyCorleone
- USA
I have an XC100 south in 2020 with just short of 3K miles. Recently I had a fault code of E25. I had it once before and found a faulty brake lever. Now, after I received the E25 error code, my screen went dark and will not come back on. I disconnected each brake cable separately, nothing. I repeated this more than once. I remove the battery (full charge) and reinstalled, still nothing. Disconnected the display cable hoping that might work, nothing. So here is where I am at. I tilted the bike on the kick stand elevating the rear wheel. I pressed the start button and accelerator lever at the same time and the rear wheel powers up but still no light on the LCD display, The only way I get power to the rear wheel is to press both buttons at the same time with the rear wheel elevated. Maybe I should try to ride it that way for a short distance and maybe shake things up. Anybody have any thoughts. I would be most appreciative.
