Known Issues & Problems with Shocke Products + Help, Solutions & Fixes
Ann M.
No ebike is perfect, this is a thread dedicated to sharing known issues or problems with electric bikes from Shocke as well as any help and solutions you know of. Sometimes that means a DIY fix and other times it can mean a recall, software update or part replacement by a dealer.
Please be respectful and constructive with feedback, this is not a space for hate speech. In many cases, representatives from the company will see feedback and use it to improve their product. In the end, the goal is to enjoy riding and help each other go further and be safer.
Shocke Electric bikes: Surge & Ampere problems.
BAFANG C961 screen, 20150926, v1.2.5 219. Motor 8FUN
1. Batteries no longer available for these discontinued bikes. Alternatives ? A simple design, just a box in the frame, 2 connections and some alignment pins, but no batteries being offered. Are there really so few of these ?
I am in Novato, California
  1. Surge just shuts off after a few minutes of use. Runs no-load at a steady 24.5 KPH, steady red light on sensor. No apparent corrosion, damage or loose connections, some discoloration on computer screen. ( Temporary, went away) Battery shows 44.5 charge.
  1. Today I reprogrammed the computer to read in MPH, made a few other changes, and went for a ride. Got about 4 miles before the display went off and operation quit, with a distinct click from the display. Does the click mean a switch was thrown ? By what mechanism ?
  2. Turned it back on several times, it immediately quit again. Worked with throttle, managed to get an Error 4 (throttle error), no other information from the display.
This battery is about 6 years old, maybe a little more. Light use, always dependable until now. Seems to charge up fine, run OK until it warms up, then stops. Are there diagnostic steps I can take ? I assume if I trace down the cables, I will find a cable port somewhere.
