My Dost Kope was in the first shipment, and I have ridden it more than 1,200 happy miles since July. I would mention a few things here:
1. the customer service from Dost really is exceptionally good. Helpful, timely, responsive, friendly, and cheerful.
2. the bike was shipped with a derailleur b screw position that provided inadequate tension on the chain, which caused the chain to jump off the chainring inappropriately when shifting, or over bumps. Watch the excellent park tools video on you tube to check your adjustment to fix this easily -- chain guides are not needed.
3. the bike was shipped with an insufficient range of pedal assistance (only medium and high PAS levels, no low setting and no gradations). This was a problem only in the very first shipment of bikes, that was fixed for my bike quickly and easily by a Dost-supplied flash update to the controller, which I understand was applied to all subsequent shipments.
4. a new problem at about 1,200 miles was that the Shimano shift sensor had to be replaced as a warranty repair. The shift sensor has a little roller sensing movement of the shift cable. It can stick in place temporarily, inhibiting movement of the shift cable so it does not travel the index distance as required for timely shifting. This shows up as delayed shifts or crashing through the gears. I am replacing the shift cable housing and shift cable at the same time. Ideally the bike would have come with a higher grade drive train but I understand this is a tradeoff to a higher price on the bike overall so I have no complaints. It shifted perfectly for 1,200 miles before needing this maintenance. If the sensor fails again, then I will look into upgrading the chain, cassette, shift trigger, and derailleur together as a package. (but at this rate, the bike will be a couple years old at that point.)
That's it in the problems/issues department!
