Easiest way I know to find the correct psi for any tire/ rim combo to suit an individuals needs is to start at a high psi and ride. Lower the psi in each tire incrementally riding at each setting on your typical riding surface. At some point you will go low enough to feel sluggishness and affected handling. Raise the psi back up to where it feels the best.
