tomjasz
- USA
- City
- Minnesnowta
We’ll find one.He needs a 14S charger
LOL....No Social Media here whatsoever.....reversed the charges yesterday...Wow, that really is poor support. I was hoping they were getting better at support, but I guess not. You probably need to port to their Facebook channel to wake them up. Of course if you are smart and don't use facebook, then your options might be limited, but hopefully at least you get your money back one way or another.
You should not have to worry about prematurely killing the battery. Even using the 6Ah charger on a low 13Ah battery you are under 0.5C charge rate which is well in spec for normal charging. if you are charging a larger battery it is even more conservative. That charger should be fine as long as the quality is good. Just don't leave it plugged into the charger once it is charged. That charger says it has a small 'trickle charge' after full charge which is bad for Lithium Ion, so unplug the battery when charged.Final post on this one: Bought a charger off Amazon. It was $58 US. It does 6A charging and has a fan. Worked like a charm! Bike is now completely charged.
Juiced never got back to me about the incorrect charger they shipped me. I reversed the charges on my Credit Card. I was credited the full amount. I sent Juiced another email stating I would return the charger to them. Nothing. Not a single returned email from customer support in 6 weeks. Strange indeed.
My only concern is that the 6A charging is quite a bit faster than the standard 2A or even the faster 4A chargers. I don't want it to denigrate the battery capacity prematurely.
Thanks again for all of the assistance and good luck with your bikes.
