Juiced bikes - do they use standard battery type / mount?
iamjcl
I was looking at the Biktrix bikes, and apparently there is a standard of sorts for ebike batteries, and the Juggernaut appears to use that type of mount / connection.
Apparently you can use other batteries from other sources on those bikes.
It looks at first glance like the Juiced bikes also use something similar.
Can you use "generic" or aftermarket batteries on some of the 2019 Juiced bikes (or other manufacturers')?j
I was under the impression that they were all proprietary (I know for sure some are, anyway).
Thanks
Juiced bikes use a reention dorado 440mm battery. The 52V 19.2 AHr pack is unique to Juiced but will fit any bike that has enough space in the triangle to clear the pack. So you can get 48V 21AHr packs from alibaba vendors and it will bolt right on.
The main thing you have to watch out for is the battery length. I have a Juiced bike, and I think they use one of the shorter Dorado battery lengths. The difference isn't large enough to discern in pictures, so make sure you have the exact measurements of any replacement pack. I suppose you could also put a battery in one of those triangle bags, and run the wire to the battery connector on the bike. Thankfully Juiced didn't employ any proprietary electronics in their batteries. Just a positive and negative connection.
OK very good to know.
One less thing to worry about, manufacturers continuing to provide proprietary batteries.
Thanks!
