Anyone know at what voltage the Ultra BMS balances the cell packs?
I'm moving to a 80% max charge (52V) for most trips in order to extend battery life (100%-54V only for long rides). Does the BMS balance the cell packs as it charges (e.g. even at 80%) or only after full charge? Apparently some BMS balance by draining the highest V cell pack once full charge is reached & then charge all again (allowing the lower V packs to "catch up") which means you don't rebalance unless you fully charge for a while.
Thanks
Thanks
