GuruUno
LOCAL PICKUP ONLY!!
$499!!!
LIGHTLY USED Less than 500 miles
*DEAL OF A DEAL*
Cash only, pickup in Metuchen
HAS 2nd BATTERY!!
RANGE IS 50+ MILES!!
This was my wifes' e-bike, she hardly ever used it, but when she did she had a blast!
This is the "Class 2: Speed Pedelec" which has a 'Boost' throttle for an additional ability to use the throttle at startup to give the extra kick when you are to pooped to pump to participate!!
This ebike has many, many years left, and the batteries are still having many, many, many charging cycles left.
Go on eBay, look around, the batteries alone go for $350-$450 EACH!!!
Specifications
IZIP E3 VIBE LS LITHIUM ION (LIFEPO4) 6.4 AH
Year 2012
Manufacturer IZIP
Model Name E3 Vibe LS
Trim Name Lithium Ion (LiFePO4) 6.4 Ah
Motor Type Exclusive Currie Electro-Drive®, Alloy Shell, 250W DC Brushless Planetary Geared Hub Motor/30 Nm Peak Torque, 10.2 Nm Rated Torque, 250 Watts
Battery EV Rated Rechargeable Lithium Iron Phosphate Energy Module, Advanced BMS, Locking Rear Rack Side Mounted, 24V6.4Ah 154Wh
Charging System UL Listed Currie Smart Charger with LED Status Indicator Display
Motor Controller Exclusive Currie Electro-Drive®, Fully Potted, 24 Volt with Power Gauge Function, Pedal Activated Sensor with Pas/Tag Selector.
Top Speed 15 mph/ 24 km/h maximum (Rider Weight, Input and Terrain Contingent)
Range, Highway8-11 Miles / 13-18km throttle only, no pedaling or up to 15-22 Miles / 24-32km with rider pedaling. *INCLUDED IS AN Optional Second Battery Pack to Add Range
Drive System Exclusive Currie Geared Hub Motor, Shimano Acera Rear Derailleur, SRAM Grip Shift, 7-Speed Drivetrain
Brake System Type Alloy Linear Pull with Alloy Brake Inhibit Lever
Wheels Alloy 26" Rims with Stainless Steel Spokes, QR Front
Front Tire Currie Comfort Tires 26" x 2.00" , Slime Self-Sealing Flat Tire Prevention System
Rear Tire Currie Comfort Tires 26" x 2.00" , Slime Self-Sealing Flat Tire Prevention System
Handlebars High-Rise Bar
Handlebar Stem Alloy Adjustable Angle Stem, Dual Density Grips
Fork Suspension w/Alloy Crown and Legs
$599!!!! 2 batteries
A Battery costs $300+
There are 2 that give 50+ miles total and have tons of life left!
Features Power and PAS/TAG Switches Conveniently Mounted on the Handlebar, Easy Access Charger Port in Removable Battery Pack, Twist Throttle with Battery Gauge, Rear Rack
Seat Type Velo Suspension Comfort and Micro-Adjust Post
Frame Type Exclusive Currie Aluminum Comfort Design, Fender and Rack Mounts
Bicycle Crank Alloy 44T Crankset, Double Chainguard
Pedals Resin/Rubber Non-Slip Pedals
Weight 53 lbs / 24 kg
Seat Height Diamond Frame, Low Step Frame
Battery Life 1000 Cycles
Battery Charging Time 2-3 Hrs
$499!!!
*DEAL OF A DEAL*
HAS 2nd BATTERY!!
Specifications
Year 2012
Manufacturer IZIP
