Limeybastard
- USA
- City
- Florida Unfortunately.
I’ve looked at some YouTube videos but still have issues. I basically adjusted the back caliper as it was binding. The issue I have now is that rear caliper brake lever travels all the way to the grip and doesn’t provide adequate rear braking. Initially I thought it was because I had turned the hex screw behind the caliper too far outwards, so I removed the caliper and turned the hex screw all the way in then out one quart of a turn. Re-installed caliper but problem still persists with brake lever travel. The brake lever cable is fully turned in clockwise at the lever side and caliper side.
