Tony Lee
Model IPS191 / LHOTZ340
Battery 340Wh lithium battery
Max Power Output 1000 Watt
APP YES
Capacity 120kg
Tire Size 16 Inch
Max speed 30 Km/H
Charger 67.2V/2A
Charging time 3 Hours
Charger Voltage AC220V (50-60Hz)
Max mileage 40Km
Balance System XIMA V0.0
Gyroscope Six-Axis
Warning System Sound / Light / Electric
Control System Sine Wave
Max Climbing 30 Degrees
Enviroment Temperature -10°C ~ 50°C
Limit Uphill Slope About 58%
Distance from the ground 107 mm
Padel Material Aviation aluminum alloy
Shell Material ABS+PC
IP Level IP65
Product Size 501.5 x 472 x 182mm
Net Weight 13.9kg
Gross weight 16.9kg
Color Black & White
Skype:ipsunicycle
WhatsApp:+86 185 8015 0195
Web: (Link Removed - No Longer Exists)
Email:[email protected]
APP YES
Capacity 120kg
Tire Size 16 Inch
Max speed 30 Km/H
Charger 67.2V/2A
Max mileage 40Km
Gyroscope Six-Axis
IP Level IP65
Net Weight 13.9kg
Gross weight 16.9kg
Color Black & White
Skype:ipsunicycle
