Off road all day
For those with hydraulic brake systems this is my best advice, silicone dot 4 car brake fluid.
I swapped it in because my Dodge Dakota brakes had to be rebuilt or replaced every 4 years because of off road use. After the change no replacement even after i sold it 6 years later.
Silicone keeps rubber parts fresh unlike brake fluid or the mineral oil they use in bike brake systems which deteriorates rubber. Silicone fluid also is less effected by temps so in cold weather your brakes still have the same grip.
On new systems just put the silicon fluid in, for older bikes flush the system out with denatured alcohol then install the silicon fluid.
I drove high lifts in the 90's, the only fluid allowed on the braking system was dot 4 silicone.
Oil based fluids and silicone based are not compatible! MAKE SURE ALL OIL BASED FLUIDS ARE FLUSHED AND REMOVED!
