Zoro Edward
I am a big fan of Juiced bikes - I own (2) HF1100's and a city scrambler
like most days, I ride my bike , park it at the end of the day, and repeat .
Today I powered up the bike - hit the thumb control - and " nothing " -
Rear hub makes a slight click sound - and will not go -
I checked the torque sensor - when I peddle - nothing happens -
I checked all wire connections, swapped out the battery,
opened the battery compartment , to check if anything was loose -
Everything looked good, no errors on the display,
Since I own (2) HF1100's , one silver and one black .
I parked the 2 bikes side by side, and cross swapped the HUB motor connections.
And found that the silver HF1100 hub is the failed component ( not cool )
I called Juiced tech support , Mark the tech said it sounds like the clutch is the issue -
It was suggested to lift the rear of the bike up off the floor (about 12 inches)
And carefully drop the bike several times to possibly release the clutch -
To no avail - My rear hub is still not cooperating
Has anyone heard of this ISSUE - It befuddles me on what to do next -
Thank You in Advance - Zorro
