If I wanted to figure out the average amount of power my e-bike is adding, is it right to simply calculate the amount of W-hr used and divide it by the time?
E.g.,
Sample Inputs
Battery capacity = 500 Watt hour
Battery started ride at 100%
Battery ended ride at 50%
Ride lasted 1 hour (60 minutes)
Calculations and Outputs
Battery used 50% * 500 Watt hour * 1 hour = 250W average output
Not reflected = inefficiency / power loss from the battery to the motor and in the motor
(distance traveled doesn't matter)
I know my motor is rated at 250W nominal but I think if I use this calculation, the result will typically be an average output well above 250W and I'm curious if I'm thinking about this the right way
E.g.,
Sample Inputs
