I have a kt controller, eggrider V2 and a 1500w motor and battery.
I'm trying to wire up the correct phase wires and hall wires. I've gone through all 36 combinations of wiring. There are 3 'good' combinations.
My problems comes with all of the 3 good combinations lose power after 10 seconds or so. if I release the throttle and press in in again, the motor continues to go well for another 10 or so seconds... The same issue every time.
I am assuming this is an issue with the controller? Is this right?
I've tested the battery on another bike, throttle tested fine and motor tested fine on a tester.
Any ideas?
Any ideas?
