TooMuchWitt
This was user error - I bought a Kinekt suspension seatpost and it worked out perfectly.
Good point. Not sure it would damage the frame, but could get wedged in if it slipped and the rider weight jammed it into the curve. So with that curve, you wouldn't get much more depth anyway. Cut a little off the bottom of the seat tube if you need that.Could be intentional, to prevent you from moving the post too deep and into the bend, which might damage the frame.
No, both of our '19 Trekking 7.0's are high step diamond frames.TBH, your pic looks more or less the same as what I see in my tube. Mine has a small lip also that only goes about 1/2 way around the inside surface roughly 1" up from the bend. FYI, My seat tube is approx 320mm down to the bend.
Maybe @TMH will weigh in? They have a couple Trekking 7.0 ebikes and I think at least 1 is a lo-step.
Maybe your setting your saddle too low. Are you trying to setup the bike so you can rest your foot on the ground from a sitting position? That wouldn't be the best thing to do with a trekking style bike. It's not good for your knees, hips or back and you won't have a proper pedal stroke. You'll have less power. There are crank forward, flat foot bikes designed for that style of riding. Properly set most people can barely touch the tip of their toes with one foot. If that. You really need to leave the saddle to put your feet down. A 52cm frame should work for most 5'-11" riders, unless you have a short inseam.I sure hope that I got the right frame size! I bought the step-thru 52cm frame, and I'm 5'11".
As it is, I probably only need to take 2 inches off the post, so it's not the end of the world.
Unfortunately, the seat tube being so long (relative to other bikes with similar geometry) makes it so I'm going to be just-shy of the clearance needed for a suspension seatpost. That sucks cuz I was looking forward to getting one.
I think the Kinekt is the lowest out of the popular ones (can't use Suntour or ShockStop due to having the preload adjustment on the bottom of the 350mm post)
If anyone has the kinekt, what is the lowest clearance that would work for it?
I'll do a full write up in the Haibike forum!
Just pumped up the tires and took it on a ride around my parking garage - everything seems to be in order. The motor has a slightly higher-pitched whine than the one I demoed, but that's likely due to being brand new.
Yeah, looks like it's entirely possible I went one size too big on my frame lol. Haibike sizing is weird......
Actually, it's possible I'm just used to too-small frames and seat heights, and it's something that I'm going to have to get used to.
Looks like 4.5" will be about the minimum "exposed height" you would need for a Kinekt.Yeah, so as it stands, the "max insert" setting is about 1" too high. It will fit me if I change the exposed seatpost from 5.5" to 4.5", so I just need to cut off part of the seatpost to make that happen.
Ravi, do you happen to know if 4.5" is enough for a kinekt? Or should I just be happy with it as-is? lol
I would not cut a seat Tube before going to a Bike Shop and making sure your Frame size is correct : I am between 5'11-6'0 : My frame is 58CM : Maybe the sizing is different : Go get a fittingYeah, so as it stands, the "max insert" setting is about 1" too high. It will fit me if I change the exposed seatpost from 5.5" to 4.5", so I just need to cut off part of the seatpost to make that happen.
