Stefan Mikes
Gravel e-biker
- Europe
- City
- Mazovia, PL
Them Germans!Flow is annoying in one respect: It says, "You may be riding in places where your bike is not legal." This is in my own neighborhood! Maybe because there is one dead-end street that is technically a private street? My neighbors absolutely don't care. We wave and shout hello.
My situation is very different from yours, as I can 1) Adjust the assistance levels at the granular level (in 5% decrements/increments) 2) Replace the Range Extender. Yesterday, I was some 8 km from home, and it was 9% for the main battery and 12% for the first Range Extender (in Specialized terms, it was 15% total charge). If the total battery charge goes below 10%, the motor goes in the "derated" mode and becomes very slow. Also, either of the batteries may cut off when it is individually below 10%. I had a climb ahead. Took no chance as I would lose the assistance right on the climb, so replaced the Range Extender in advance. Now, I had 9/100% or 59% total battery in Specialized lingo.This is the reality we all started with, and I can live with it. After a steep climb, I may have only 20% battery, but whether I know whether it's 22% or 18% may not matter that much in terms of whether or not I can make it home! Wind, my own exhaustion, etc. will be such significant factors that the granular detail does not matter to me so much.
Please never trust the average cadence value as it never works in any system if you are coasting (Wahoo or Garmin would cheat, too). Only the current value of cadence (as you are pedalling) matters. Whenever I'm pedalling, my actual cadence is at least 78, and I try to maintain it above 80 but Wahoo reports it as 64 on average.Here is where Flow+ gets interesting, because it tells me that my average cadence is in the mid 60s, though I max out only in the high 60s?!
The text above the chart is misleading. It is true your legs provide high torque to the cranks when you "mash" the pedals, and it is a high value of cadence when you "spin" the cranks. However, the mid-drive control system is mostly interested in the leg power input, which is Power = Torque * Cadence. The proper way of riding an advanced e-bike is to use gears so your cadence is roughly constant and >70 rpm. You downshift to start the ride at a high cadence, and you upshift to maintain the cadence as you are riding faster and faster (this is why derailleur was invented in the first place!)So maybe I'm really not pedaling fast enough to get max torque in Tour+. I wish it gave me in-the-moment cadence numbers, but this is helpful. I found this chart, too, though I'm too stupid to figure out what it means. Does it mean that I don't get more torque until I'm north of 100 cadence?
However, mid-drive motors become efficient at higher cadences (from 70 rpm up), therefore you shall never "mash" the cranks but "spin them".
Now, the infographics is crazy if it is true! It tells you that you should spin your cranks at the cadence 100 to get the maximum power of the SX motor! Nobody except some pros can pedal that fast on a continuous basis. Cadence 100 means you are in a low gear and spin the cranks like a madman! (My max cadence of yesterday was 109 because I downshifted too much and indeed pedalled as a madman for a short while I was overtaking a road cyclist).
The bottom line is: You can only get the maximum power of the SX motor when you pedal crazily fast, which is unlikely to happen.
