As someone already explained the controller does not convert one voltage to another. Rather you choose the voltage to be used and the controller has the ability to power the motor at the chosen battery voltage.I know people tend to "over volt" motors, but that doesn't mean the controller itself can convert certain voltage into something else.
Many users report running MAC motors at higher power and getting several thousand miles of trouble free riding. Metal gears are CRAZY loud. Occasionally you'll find a user that has used ONE metal gear and claims improved gear life. But again, MAC and eZee motors are well known for reliability and long service life. Charging out a clutch/gear assembly is easy peasy.OK so these things will fix the problem
Using the Grin tools will reveal the heat failure point. See the motor simulator.Is temperature the biggest concern?
B/c she’s probably 50 or 75lb -100lb lighter then you are ??FWIW, my wife's Haibike Sduro Yamaha 36V 500W mid drive ebike, can easily do 28mph with twice the range as my 500W 48V hub drive ebike.
Efficiency.B/c she’s probably 50 or 75lb -100lb lighter then you are ??
Amazing motor. Built in torque arm, regen braking, 28mph, neat clean wiring, and all the advantages of the proven MAC gearing. Just when I already am 3 projects behind I have to droll over this.
I’ve learned that my beloved mid drives and their complexities have a solid competitor.
At the top of my to order list is the solid 25mph GMAC with a 10s, 36v, Battery. A 35E cell 17ah pack adds parallel cells instead of more in series and offers great mileage. While everyone around me is dumping more amps in search of higher speeds I’m excited about decent speeds and better efficiency. That and supporting mid drives, I have 4, gets tiring compared to care and feeding of hub drives.
https://www.ebikes.ca/product-info/gmac.html
Having a bike builder adopt this system would excite me. But the wiring scheme of this motor is quite well designed and could be a DIY that doesn’t look like an advertisement for zip tie makers.
Different motors. Different uses. The newer Bafang G310 and similar are GREAT. Mac has been around a long time based on the top shelf BMC. But no MAC is sized like the new Bafangs. I think eZee is a bit above MAC but likely eZee wouldn't or wasn't interested in the development of a new concept with Grin.so is MAC superior to Bafang?
Because Juiced CCX or RCS have Bafang, but for HF1100, they went with MAC. I'm assuming MAC can handle somewhere near 2000W max?
Looks like you answered your own question.The HF has 1100W nominal and 1813W max.
No. Not if you want the features Bafang offers. eZee is about the size of a MAC. I'm not sure what you're on about there.so MAC is superior to Bafang?
I like how compact Bafang is though, and eZee is way too big to the point it's just aesthetically unpleasing.
Correct! Programmable controllers are common. EM3ev, Grin, Lyen, and others.
Sadly the Lunatics have done a lot to bring on silly rules. We’re I a useless asshat with no respect and 14 years old... I feel your pain. Thankfully we’re lucky enough to have adults as our primary customers. It just amazed me to see asshats do 35mph capable kits on Walmart $200 junkers. Bikes that 99% of bike shops won’t even look at. Go figure. I be learned, having built fast bikes, they are an accident waiting to happen. Car drivers see bicycle and expect sub 15mph bikes coming at them. At 35 I think we invite a mishap. But then what do we know... sometimes it’s good to be old! Thanks Feliz! All the best!Wreckless idiots riding at ridiculous speeds have ruined it for eBikes on our trails/paths around here.
Programmable controllers and improved battery technology are the future. I don't care how fast I go, I've never had a bike I can exceed ( I've had bikes that will but I won't ) 20 mph. Wreckless idiots riding at ridiculous speeds have ruined it for eBikes on our trails/paths around here.
Needed to go to the specs this morning and confirmed, eZee is about the size of an 11/34 cassette. Actually a bit smaller.eZee is way too big to the point it's just aesthetically unpleasing.
