Going over bord with the Ebike!
Amish David
Hopefully next month I will be purchasing my rear 1000w. System and a 20 amp hour lithium battery pack. I am integrating a 12-volt motorcycle battery in the middle of the frame which still allows me to Pedal. This will run my LED headlights blinkers brake lights and parking lights. I have already installed the blinkers I used a 3-way toggle switch for the controller. For the brakes I simply added a returnable toggle switch at the disc brake arm. I will also be adding a headlight to the front fenders that I am building right now. I will be installing smooth head bolts so it doesn't look so tacky and also painting it to match the bike when I am done. So what did you overbord on?
