shark_jumper
Hi, new to the forum and first post. I'm an avid mountain biker, but due to work, family, etc. I only get to MTB maybe 10 miles/week so so I would call myself moderately fit. Due to a frustrating 6 mile (one way) commute in stop-and-go traffic that takes a half hour, I'm going to start bike commuting. I have found a safe route to work (about 40% bike paths, some paved, some not, 60% streets) that will be about 7.5 miles. There will be one 500ft. climb (on the way home) over a 3 mile stretch with some steep pitches, otherwise mostly flat. I'm willing to spend up to $3K. Been doing a lot of researching, and these are my top 3:
2019 Giant Quick E+ ($3,150)
(Giant Syncdrive Sport (aka Yamaha PW) 80nM torque 250W, 36v 13.8Ah battery, 3A charger)
Pros: Giant dealer support, nice high volume 27.5 x 2.35 tires, tubeless ready rims, Deore Shadow+ 10sp drivetrain
Cons: QR rear axle (rather than thru-axle)
Juiced CrossCurrent X ($2,499)
(Bafang Geared Hub Motor, 80nM torque, 750W, 52v / 19.2 Ah battery, 2A charger)
Pros: higher wattage / voltage (but same torque rating), throttle option
Cons: 700c x 45 tires, 19mm internal width rims (lower volume/harsher ride), plastic fenders, AA battery powered tail light (rather than integrated like the Giant and IZIP), Altus 9sp drivetrain), low-end boat anchor Suntour fork (would rather have a rigid fork than a crappy suspension fork)
IZIP E3 Moda ($2,999)
(Brose Speed. 250w 36v (? torque - not specified) 13.8 aH battery, 4A charger)
Pros: best brake setup of the bunch (Tektro M735, 4 piston front/ rotor, 2 piston rear 180mm rotors), thru-axle front and rear,
Cons: can't see any obvious ones, but to nitpick, non-clutch derailleur, 11-32 cassette (rather than 11-36 like the Giant)
Any thoughts on these three in relation to each other, or others I should consider? For the mid drive bikes, any thoughts on the Yamaha vs. Brose systems? The Giant and the IZIP are pretty competitive with each other, and the main significant difference is the motor system. Thanks in advance!
