I had the same problem with finding LiquidPaint.
Have the LiquidTape, 42T BlingRing on order. Have fully charged battery to 100% - on short ride up significant grade with no fluctuation. Will adjust rear deraileur tomorrow after guests depart.
David
Liquid electric tape is a poor choice for electric bikes.. It is meant for severe wet conditions like on a boat trailer a bilge pump or some other maine application. It's messy. I've owned 5 boats and only used it on permanent connections like battery terminal strips....
Heat shrink tubing is effective and easy and clean to replace.. I don't even heat shrink the tubing.. Just tie the ends with mini tie wraps.
I have ridden ebikes for 6 years in Miami, which is probably a lot wetter than wherever you are, and never had a problem.
http://www.amazon.com/b?node=700782011
