I would review EBR for both Voltbike and Radrover to look at the fine details of both bikes.  I was on the fence a year ago trying to decide between the same two bikes for the same $$$ (cheaper shipping with Volt).  What I liked about the Radrover was it was a fat tire bike with ebike components added.  I could repair/replace as needed any parts once the warranty ran out.  I can even transfer all the ebike components to another fat tire bike and convert the Radrover into a regular pedal bike. Because the battery is standard, I can also upgrade up to 52v/13.5ah version for more power and range from Luna Cycle because the standard Dolphin battery pack fits into the Radrover battery tray. What also pushed me towards the Radrover was:
- riding position was more upright with a shorter handlebar stem
- had ergonomic grips for added comfort
- has a twist throttle with on/off switch, later added an aftermarket thumb throttle attachment I use when trail riding
- throttle is available with full 750 watts of power in PAS 0-5, comes in handy if you need to walk your bike up inclines or stairs
- the controller is made to deliver full power you are set for until power is depleted (kinda like a car giving you full power until you run out of gas).
- front suspension has a lock-out feature
- 180mm brakes front and back
- neoprene slap guard for chain
- three built-in water bottle mounts (either side of upper top tube and one on down tube facing the ground)
- two different colors for his and her ebikes
- standard rack ready connections (went with Topeak fat tire rack)
- more comfy standard seat
- option for PAS 0
- quick release on front wheels
- I can add a triangle bag to cover the battery to dry, dust free, and warmer during winter rides
- you can adjust the motor cut off speed in the LCD screen setup, you can set the RR from 7 to 24.8 mph motor cut off.
This was a year ago and I'm sure Voltbikes has made upgrades since then.
