Ecotric Rocket - Electric Bike Review
Ennovation
Hey there, my friends! Today we're checking out the Rocket from Ecotric. This bike is a 500w, 36v, Hardtail Ebike that is suited for light trails and having some fun. Check below for our full list of specs.
Ecotric Official Website: https://www.ecotric.com/
🕵️‍♂️ Looking for more Ennovation reviews? - https://www.youtube.com/ennovation
💸 Gear We Use 💸
👉 Nikon Z6 - https://amzn.to/3sdB62R
👉 Nikon Z50 - https://amzn.to/3ktnVsf
👉 Z CAM E2-F6 - https://amzn.to/3sdB62R
👉 DZO Vespid Lenses - https://amzn.to/3sdB62R
👉 Nikon 24-70 F/4 - https://amzn.to/3sdB62R
👉 Benro Tripod - https://amzn.to/3sdB62R
👉 Weebill S Gimbal - https://amzn.to/3sdB62R
👉 Xero Shoes - https://xeroshoes.com/go/mitch4rk
🎥 Channels We Love 🎥
🚴 Electric Bike Review - https://www.youtube.com/user/ElectricBikeReview
🚴 Electrek - https://www.youtube.com/c/ElectrekCo/
🚴 Electroheads - https://www.youtube.com/c/Electroheads/
🚴 CitizeCycle - https://www.youtube.com/channel/UC3R3156SHX__ZHM47xtw6pw
🚴 Bolton Ebikes - https://www.youtube.com/c/BoltonEbikes/
📊 Other Resources 📊
🚴 ElectricBikeReview.com Forums - https://electricbikereview.com/forums/
🚴 Electrek - https://electrek.co/
00:00 Intro
00:26 Overview
00:50 Looks
01:30 The Riders
02:32 Motor
03:01 Battery
03:58 Brakes
04:46 Gears
05:19 Extras
05:56 Essentials
06:45 Suspension
07:45 Controls
08:38 Ride Test
19:14 Final Thoughts
19:47 Outro
MAKE:
Ecotric
MODEL:
Rocket
PRICE:
$1,000
BODY POSITION:
Upright
SUGGESTED USE:
Neighborhood, Urban, Beach, Snow
ELECTRIC BIKE CLASS:
Class 3
WARRANTY:
1.5 Years
AVAILABILITY:
United States
MODEL YEAR:
2020
TOTAL WEIGHT:
56.20lbs
BATTERY WEIGHT:
9.14lbs
MOTOR BRAND:
Ecotric Branded
MOTOR TYPE:
Geared, Rear Hub Motor
MOTOR NOMINAL OUTPUT:
500 watts
BATTERY VOLTAGE:
36 volts
BATTERY AMP HOURS:
12.5 ah
BATTERY WATT HOURS:
450 wh
BATTERY CHEMISTRY:
Lithium-ion
CHARGE TIME:
7 hours
ESTIMATED MIN RANGE:
15 mi
ESTIMATED MAX RANGE:
23 mi
DISPLAY TYPE:
S900
READOUTS:
Speed, Battery Percentage, Pedal Assist Level, Odometer, Errors, Also Includes USB Charging Port
DRIVE MODE:
Speed Sensor
TOP SPEED:
20 MPH
FRAME MATERIAL:
6061 Aluminum Alloy
GEOMETRY MEASUREMENTS:
19" Seat Tube, 19" Reach, 31" Stand Over Height, 26" Minimum Saddle Height, 32" Maximum Saddle Height, 28" Width, 46" Wheel Base, 76" Length
FRAME FORK DETAILS:
Adjustable Front Fork Suspension with Lockout
ATTACHMENT POINTS:
Fender Bosses, Rear Rack Bosses
GEARING DETAILS:
7 Speed 1x7 Shimano, Shimano Tourney Derailleur
SHIFTER DETAILS:
Shimano SIS Index (Right Side)
CRANKS:
160mm Prowheel
BRAKE DETAILS:
Tektro Aries Mechanical Disc Brakes, 160mm Discs
GRIPS:
Ergonomic Faux-Leather, Non-Locking
SADDLE:
Wide Selle Royal
TIRE BRAND:
Chaoyang
WHEEL SIZES:
26"x4"
TIRE DETAILS:
20 Max PSI, 1.4 Bar
TUBE DETAILS:
Schrader Valve
ACCESSORIES:
Bell, Rear Reflector, Front Reflector
OTHER:
Locking Removable Battery Pack, 265lbs Max Weight
Ecotric Rocket Ebike Urban Class 3 Review Budget Shimano
I "liked" your review! Informative.
All the inexpensive bikes seem to have have the Textro Aries 300 calipers. I used to aspire to them when my first converted ebike only had rim brakes, but I learned they were the common denominator of disk brakes.
Converting from rim brakes to SRAM Avid BB7's mechanical calipers was not necessarily an improvement for my bikes. A good set of rims were always quieter, and often felt better. A lot of entry level ebike owners are converting to cable actuated hydraulics. I've not tried that. I have installed Shimano hydraulics on one bike.
Anyway, 100 dollars on ebay will possibly get you a Shimano quickfire trigger shifter and a front/rear set of Shimano levers, tubing, and hydraulic calipers. Drops right in, except you have to glue on some $20 switches to keep the electrical cutoffs. . They're just inexpensive bit/pieces. No need to obsess over not having them. And $7 for a good bell at Walmart.
Hey Harry! I actual just installed some Shimano MT200s on a MTB Build I'm doing, and it was MUCH easier than expected :p Definitely a recommended upgrade, in my opinion. It's not electric, so i didn't have to worry about the cutoffs, but an excellent tip for someone who wants to keep that feature if their bike has it!
