Ann M.
Well, it's blazing hot in Texas this 4th of July, so what fun to envision riding in Snow! This is the upgraded, 2016 version with the bigger 48V battery pack with 50 more watt hours. The black spokes & motors give the dual motor system a stealthy look. More nimble than the fat tire version and capable of better grip and acceleration in both loose gravel as well as snow. I'm really impressed with the BH app that can be used with this bike and others.
https://electricbikereview.com/easy-m... The Easy Motion EVO Snow 29er Pro is a more powerful version of the original EVO Snow offering 48 volt battery and higher amp controller, delivers two hub motors for improved traction in snow and soft terrain (gravel, sand, mud). Clean integrated battery and wires are hidden inside the downtube, high-step frame is stiff and sturdy but approachable thanks to an angled top tube, this lowers stand over height. Quick release levers on both wheels despite having integrated hub motors and cables, this makes maintenance and transport much easier, battery and display panel are easily removable. Pedal assist only vs. some older Easy Motion models with throttle operation too, pedal assist cuts out a little slow and can activate with chain bounce on rough terrain, increased unsprung weight and slight handling inertia increase in front wheel due to the hub motor.
