6zfshdb
- USA
- City
- Northeast Pennsylvania
With the dual battery option, do both batteries discharge at the same time or does one deplete first and then switch to the other? If both batteries discharge simultaneously, both will have to be recharged after every ride even if neither is fully depleted. With only one charger, this will require charging one battery first, then connecting the other. This means a 2 step charging process after every ride, even if it's a short one. I suppose this issue could be solved by buying a second charger or a "Y" connector if one exists.
