Hello fellow cyclists,
I would like to build my own e-bike but the google up the mountain quickly threw monkey wrenches my way. Sourcing a frame turned out to be a formidable stumble block. My current setup is a very sturdy Lynskey Backroad touring frankenbike with a BBS02. The wide q have messed up my knees badly. Having entered the old age of constant complaining I would also like a comfort upgrade.
These are my oh-so-humble req:
Now that I've framed the problem and steered you into my wheelhouse: what the fork would you have me do? Any advice greatly appreciated!
- Mid drive - almost any brand will do (preferably Yamaha due to reliability, I also like Brose due to top characteristics and low noise). They are all on ebay, should be fine, no? Or do I need to resort to a heavy and noisy Innotrace Ultra G510?
- Belt drive compatible.
- Front geometry fitting around 50-80 mm travel forks - I guess somewhere in the neighbourhood of 450 mm axle-to-crown. (A full suspension frame would also be ok and I understand this would mean more travel.)
- Commuter specs with fender mounts etc.
- Must be able to handle at least 25 kg on the rack and some in the front without going twitchy and noodly at high speeds.
- Much prefer an integrated battery.
- Reasonably long wheelbase (1120+ for sizes fitting a 175 cm tall cyclist) without toe-wheel overlap.
