Delite kick stand?
lerxst
My Delite Mountain didn’t come with a kick stand, though it has mounting holes for one. Does anyone know where I can order the OEM kick stand online?
Thanks!
I’ve also got that Trek and am going to borrow its kickstand for the R&M until the new one arrives. I hadn’t noticed but you’re right, it is the exact same stand! Thanks!
@David Berry OK so something is wrong here. I’ve got a Trek Powerfly Speed here and the bolt hole pattern is totally different from the R&M. 22mm wise vs 45mm. So the kickstands are not compatible between the two bikes. Are you sure you recommended the correct one to me? Just checking, thanks.
PS- My measurements are probably off by a few mm because I wasn’t trying to be totally accurate. Either way, there’s a huge different in hole spacing.
I was eventually able to make the Pletscher Comp 40 Flex work. You'll need to get some nylon lock nuts from the hardware store, and also note that mounting this kickstand on the Delite requires a hack saw and a drill. Without both tools and the nuts, there is no way to mount this thing correctly, and even if you did succeed, it will be too long (even with the adjustable stand) and the bike will tip over. Thanks, everyone, for the help.
