Shea N Encinitas
First off here is a video about revamping your entry level fork, something to consider. Mine is doggin at 2K.
Second, below is a graphic where I tried to log the component weights, many missing and estimated values, submit corrections if you like, or just look at the forks (both rigid and parallel based suspension) that I'm day dreaming about. I suspect a 38C tire would get me a little distance, and that rolling weight is a killer. BTW - That Ritchy rigid would take 3.25 lbs off the bike, a good start. -Shea
EDIT: Updated graphic with Marathon Racer (tnx 4 tip), 35C is also an acceptable option, just be sure to get a quality tire with strong sidewalls. Just to be clear the Lauf Trail Racer is not compatible as it has a tapered steerer and 15 mm through axle, I just like the design and weight, maybe they will expand the product line.
