May I ask what brand and do you wear them bareback as recommended?Been wearing them for over 35 years, still riding with them, doubled up sometimes for long hours in the saddle.
If not only for the padding, the form-fitting lycra/spandex actually support your leg muscles, glute muscles and lower back muscles while cycling.
Similar to wearing a back brace when lifting heavy weights, the tight short protect your muscles during cycling activity.
Always commando under the bike short, no need for extra underwear to chafe into your skin..May I ask what brand and do you wear them bareback as recommended?
The ones I wear are Gore C3, and I wear StepOne boxers under mine which also are form fitting with Lycra.May I ask what brand and do you wear them bareback as recommended?
How many pair do you have?The ones I wear are Gore C3, and I wear StepOne boxers under mine which also are form fitting with Lycra.
For interest I tried many cheap ones from Amazon, but always found their fit to be poor. However, the Gore ones fitted brilliantly straight away.
For me, this is the more comfortable way for wearing them.
DG…
I have two pairs and alternate them every day.How many pair do you have?
I ride M-F but normally only 5 miles about 20 minutes. Not sure if it’s beneficial to purchase them for that , but would nice to have from Nov through May when the weather breaks!
it might not be worth it. I would use some pants can block wind. depends on how cold it gets to what you need.How many pair do you have?
SW Florida! Average temperatures from November through May, 70s - 50s, some 60s - 40s.it might not be worth it. I would use some pants can block wind. depends on how cold it gets to what you need.
Below 10 deg F with high winds, I wear waffle weave cotton long underwear, 2 pairs socks, combat boots, long cotton/poly dickies pants, then flock lined carhartt overalls. 5 layers on top. Cotton gloves under lined farmer mittens, oven mitts over that. Welder's helmet liner, saran wrap over helmet vents, safety glasses to avoid tears.it might not be worth it. I would use some pants can block wind. depends on how cold it gets to what you need.
from about 55 to 45 I wear golf pants as they dont wear out and are enough below that to about 32 I wear Chrome industry pants astray really keep my legs warm but can work in them. I dont want to change clothes When i get to work.SW Florida! Average temperatures from November through May, 70s - 50s, some 60s - 40s.
As a sidebar, I feel the same way and won’t even go outside without a shirt on!I wear them. As underwear under some form of nondescript cargo short. The padding is a help as the miles wear on, but the main benefit of cycling shorts are the flat seams and the multi-panel construction. Not because more panels are somehow better, but because more panels allows the seams to be put in places where they will not chafe your skin. Regular shorts and pants have for example a seam that can wind up being literally on your weiner... which rubbed upon for a few thousand times with synthetic thread is not even remotely pleasant. Walking its no big deal, but sitting, with the shorts hiked back thanks to sitting in a bicycle seat so there's no hanging down of the pants...
Strictly speaking, cycling shorts from a hygeine standpoint should be worn alone. However now that I am 60 and no longer a 6'0" rider weighing 135 lbs (more like 235) the world is not ready for my awesomeness in spandex. So I wear looser fitting cargo shorts, and try and make sure I am wearing at least 8- or 10-panel shorts underneath.
Also you can spend a bundle on shorts ... or not. A thick pad and proper panels don't have to cost a lot. Since I ride daily and wear riding shorts effectively as underwear, I have several pairs. I don't usually pay any more than about $20 for a pair.
Lastly, Spandex does not have to be skin tight. Buy a larger size than normal. So long as the fabric is not folding or sagging on you, it is able to do its job. It doesn't have to be stretched across your skin.
I have four pairs of these. They are probably my favorites. Amazon says I bought my last pair in 2021 and they are still going strong under very frequent use/washing. More expensive now than what I paid but so is everything.
I bought the XXXXLG size (yes, 4XL) and my waist is a 38. So buy oversized, but also don't forget Chinese sizing and REALLY oversize.
