Cycle Analyst
Because the controller is internal, you will need the CA-SA (stand alone) You also need connectors for the Falco Delphi connectors.
  • Like
Reactions: MLB
Thank you! Do you mean I need to tell Cycle Analyst (or manufacturer) that I need Falco Delphi connectors on it? Or get Delphi(?) connectors from Falco for the Cycle Analyst?
I got my Delphi connectors from Falco.
I put Anderson connectors on the CA current sensor so I could use it on other systems. Attached are pick of the ca and adapters next to my new Falco wheel.
