Yes to Dunbar! Dang it, though: the reduction to 114 links by itself fixed my bike's chain drop issues only for a couple of weeks. Then chain drops began again, apparently because the cocked-back OEM Altus derailleur tension spring weakened.Yeah this guy on YouTube said shortening his chain to 114 links fixed his chain drop issue. Worst case you can install a derailleur with a clutch in it. I haven’t dropped a chain since installing a Deore XT Shadow Plus derailleur on my Cross Current. The clutch prevents the chain from losing tension over bumps.
You sure could, Andy. Earlier on before getting a Deore XT Shadow Plus, I bought and then returned this guide because It would not work for the relatively giant CCS chainwheel because its entry point was located too far forward from the leading-in teeth of the chainwheel. (It is meant to work only for much smaller chainwheels.)I have a first run CCS and I have gotten the spokes replaced....with the new ones from Juiced. So far so good. 3+ weeks no issues. I have an occasional chain drop but its not really a big deal.
but i'll be interested in if anyone comes up with a good fix.
I may just design one my self and print it on my 3d printer....
Andy
https://www.bikeradar.com/us/mtb/gear/article/how-to-convert-to-a-1x-drivetrain-37451/Chain retention is the key to creating a reliable single-ring drivetrain and your chainring is your first line of defence again dropped chains.
There are dozens of companies who are now producing chainrings with alternating width tooth profiles, similar to SRAM’s X-SYNC technology. These are generally referred to as narrow-wide chainrings.
These chainrings match the width of their teeth to the width of the chain's inner and outer plates, which greatly reduces any side-to-side movement of the chain, thus reducing the likelihood of dropping it.
Wolf Tooth Components is one of several companies making aftermarket chain rings with alternating width tooth profiles
While not a necessity, rings such as these can reduce the likelihood of dropping a chain. When used in conjunction with a rear derailleur with a clutch mechanism, such as Shimano’s Shadow Plus or SRAM’s Type 2, you should be able to run your 1x drivetrain without a chain guide. (((snip)))
... I haven’t dropped a chain since installing a Deore XT Shadow Plus derailleur on my Cross Current. The clutch prevents the chain from losing tension over bumps.
I'm certain there are "how to" videos on YouTube about how to replace and adjust a rear derailleur. You can check the Park Tool site also. In a nutshell, you break the chain (either with chain tool or opening the connecting link), disconnect the shift cable, remove the old derailleur, install the new one, set the limit screws, reconnect the cable, rejoin the chain, and adjust the indexing.
Unfortunately, when we upgrade to a 10 speed derailleur we absolutely have to fit also a 10 speed shifter and a 10 speed cassette.Hey guys, how hard of an install is the Deore XT Shadow Plus derailleur? Is it pretty much a drop in replacement for a DIY guy? (hey I remodeled all three of my bathrooms...could I do this myself? - LOL) - Thanks in advance!
Unfortunately, when we upgrade to a 10S derailleur we absolutely have to fit also a 10 speed shifter and a 10S cassette.
This is basically because the index ratio of 9S to 10S is different, that is the movement-per-click of the 10S derailleur is inherently different in the derailleur, itself. It cannot practically perform 9S indexing, no matter what shifter is used.
I chose:
$31 for a Shimano SLX trigger shifter, with visual indicatorsimilar to the 9S Altus it replaces.
$30 for ZTTO wide range 11T-42T 10S cassette.
$22 for KMX X10.93 10S chain
$65 for this 10S Shimano (get the long cage!) Shadow Plus derailleur.
It was all easy to install, using YouTube videos for guides. I had no previous experience with this stuff and enjoyed the learning process. Changing out the cassette was the most challenging. But not really hard at all with YT videos.
This is basically because the index ratio of 9S to 10S is different, that is the movement-per-click of the 10S derailleur is different. It cannot be made to do 9S indexing no matter what shifter is used.
Ha ha, I don't think I even know what that is about. Have heard of it. My new parts may even have it. But what is dynasys?I forgot to mention about the whole DynaSys thang. DOAH! So yes, it is not plug and play in the instance of going from 9 to 10 gears.
what is dynasys?
