bbagnell
- USA
Here's my hack for power control. Since the left brake switches, intended for a front derailleur, don't do anything, I wired them to the power controller using the wires and plugs that are supplied as an extra. I cut off the buttons on the wire set, took apart the switch on the left shift lever, connected the wire set, and now I can control the power lever with the left brake switches. It was a bit tricky taking apart the brake lever switch, identifying the wires, soldering the tiny wires together, and hardest of all, reassembling the switch, which has a set of small springs. But once together it works great, no extra buttons, just the existing Ultegra shifter repurposed. Specialized should have thought of this.
