Yamaha supposed to have their own ebikes with 28 mph coming soon. They've offered their mid drives for others like Giant to use in the Class 3 , 28 mph configuration for some time now.
Believe it when I see it. IMO, they are more of a 'purist' ebike company and might see more benefit in sticking with the 20mph limit to stay legal everywhere.
Pretty awesome for a road bike, eh??
I wouldn't mind a speedbox or something as the bikes are so efficient they hit the limiter too easily. Not to go 28 per so, but just to pickup a couple more mph when you have room to do so.
Gearing becomes an issue at the higher speeds - a couple more teeth on the chain ring would be of great benefit.
So I hear the 2020 pro motor has been improved quite a bit - higher cadence support and much quieter. Now they need a 750w pack.
Presenting a motor by its motor cutout doesn't make much sense. It is just an artificial restriction.
However I see that this high speed motor is in fact listed as a 500W motor. I am assuming that it is nominal since all of the other offerings are listed as 250W. In that case it makes sense and this may actually be a viable option for average speeds in 20-22 mph range.
Looks like a nice motor and only weighs 3.1 kg, which I believe is lighter than prior models. I wonder if Giant will be using these motors on their bikes?
Yeah the casing is the same and if the internals are also the same then it is just firmware. In that case 500w will be close to its peak and it is likely that the motor will be inefficient at higher speeds.
In fact, when Grin Technologies tested Bosch 250W motor using multimeter (or some measuring equipment), they found that 800W of electricity was going into the motor.
Mike, I got in my email a little teaser clip from Yamaha regarding an upcoming dual suspension mountain bike. Unlike the show model all decked out in bright colors and anodizing, this one was in stealth black with little to none side views of the bike going down a trail.
Looking forward to any future info you may get regarding this upcoming bike!
