cheap hitch carrier - better ways to secure the wheels?
efair
I've purchased an inexpensive hitch carrier for our two ebikes. I went cheap because it's for short-range, paved-road use only. It's adequate but it came with four rather small straps with metal squeeze-to-open buckles on the end to secure the wheels. I'm wondering if anybody has come up with something a little better for keeping the wheels where they belong.
The last two racks I owned used metal loops to hold the wheels. Wheels would be well secured by gravity, but you wanted to use the velco straps to make sure they stayed in place.
I learned later that if you get a big nylon tie strap, it can be used to wrap around the bikes in the middle of the frame and tie them to the rack. No way they bounce then.
+1 on the big nylon tie strap.
I also have one metal loop per wheel, fixed horizontally, which is a common design on the less expensive racks. And yes, the weight of the bikes will, in normal, short-range, paved-road circumstances, be adequate. However, planning for e.g. emergency maneuvers, sudden braking/swerving, unnoticed speed bump, etc, demands more security. I'm just wondering if anybody might have any clever alternatives to straps. Maybe something that locks?
