m@Robertson
Merciless (on the inside)
- USA
No extremes necessary. The tires at lower psi levels have serious traction and can carry very heavy loads at higher pressures. I've had the bike to a total ride weight of well over 500 lbs. That framework you see in the back is functional. With some straps I'll also use the bike to haul wood to the campsite from deadfalls. And the panniers I'll be carrying on the fun rides have a capacity of 138L each.More conventional rims, those used on production fatty bikes, are usually "just" 80mm or so, which is generally TWICE as wide as you might find in use on a production mountain bike. At least that's what I'm finding. Point being, 90 and 100mm rims are getting pretty extreme - and likely requiring an extreme setup just to get them functional.
I'm guessing the purpose of using something that wide is to spread out the tire tread for better grip?
I know you don't like fat bikes but they are much more functional than you think. But, all good. To each their own.
Interestingly because its a longtail it can go straight up a hill that any normal frame'd bike would flip in the attempt. This thing can ride up a hill my 29er enduro would have to be carried up (on the way back down the enduro wins).
