Is it such a small segment that only R&M are interested in this space?
I believe in integrated powertubes because of 1) Protection & areodynamics of the battery & mount itself, 2) Security (keyed in), 3) Appearance.
I love the idea of how the new dual battery Homage integrates 2 into the downtube.
Can anyone from Bosch comment on if the system can still or ever did handle up to 4 batteries.
I'd like to see a touring bike with:
2 Powertube 625's side by side in the downtube, these being the main batteries and a perfect place to put the majority of battery weight in the middle/front.
A powertube 500 or 625 in the top tube AND seat tube BUT the provision to install internally small plastic covers over each battery end mount/socket so that when no battery is installed in the tube the whole tube becomes a storage compartment, preferably with an aluminum or other hard LOCKABLE cover. And the seat tube with an option for a special mount that can firmly house standard pet drink bottles or similar. Or of course install a 3rd or 4th battery.
And even if the Bosch system can't handle a 3rd or 4th battery, a place to store a 3rd or 4th securely would be good.
Also with a mens style triangle frame, mounting points that firmly hold in place a very wide frame bag that fills the space between top, seat & down tubes completely. This has the potential to be a very large storage area.
Also mount points for special wide top tube bags, also potentially large in volume but to be able to seal the mount points when not in use.
Decent tested gross weight capacity of 160kg or more.
Decent tested weight capacity on an optional front rack and a standard fixed rear rack and the rear rack being strong in all directions so that it needs to be mounted/attached to more points than just the rear axle area.
The rear end for a hardtail to handle up to 70mm tires (for extra tire suspension) and appropriate fenders (70mm width not 60 or 65) and thru axles.
The option of original twist shift Rohloff.
Gates belt.
And last but not least for Bosch to bring back and enhance the Travel charger (12VDC input) so as to allow people to charge their batteries in-car or Solar. Preferably with a 12-24VDC input.
Tout-Terrain seem to want to stick to steel frames which makes it difficult to integrate batteries.
Koga doesn't seem to know which direction to go in.
Many other touring bike brands are seemingly just tacking on the E.
This seems ok, still not ideal in my eyes but hard to get anywhere else: https://www.simplon.com/en/Bikes/E-Bikes/Kagu-Bosch-CX-275_b_124297
Am i being too specific?
Gates belt.
