Bolts to hold on kickstand
jrlockman
My kickstand on my 2019 Rad Rover broke off and they shipped me a new one, but did not include the two mounting bolts, does anyone know the exact size, thread, bolt type for those two bolts?
Can't give you a complete answer, but I assume they are metric. Comparing with the M5 screws that fit the rear rack threaded sockets on the frame near the axle, the kickstand screw has a thicker diameter, so M6, 7, or 8. Length appears to be 23mm, but there's plenty of room to extend a couple extra mm if all you can find is 25mm length. Thread is significantly more coarse than the M5 screw.
You can buy these bolts at Homedepot. Buy one of each size and return the ones that don’t fit.
My new rad rover step through arrived a month ago with a loose kick stand from a stripped bolt. I assume it was over tightened at the factory.
I just replaced it with a stainless steel M6 bolt that was a 1/4 " longer and put a locking nut on it with some locktight.
