I have 500 watt Bafang motor with a 48 volt 13 amp hour lithium ion battery from the factory.
Can I use a lower or higher volt battery and diferent amp hour battery without damaging the 500 watt motor or do I need to stay with the 48 volt 13 amp hour battery?
Also, can i use a 1000 watt battery on a 500 watt motor without causing damage?
