@Bobh
have a look here: (Link Removed - No Longer Exists)
or directly here: http://www.chicagoelectricbicycles.com/Batteries.html
Ali-express is full of ebike batteries. The type mounted behind the seat post is called Silverfish.
Or try this "refill" place: http://www.batteryrefill.com/Ebike/emoto/index.phtml - they'll put new cells in your casing. I understand this can be done with other packs too, not just Emoto.
I did find a battery on ebay. I had a little trouble figuring out that it included parts that are intended to replace where the battery meets the bike. It didn't work at first, but I saw a lot of comments on batteries on ebays for these bikes mention the polarity. Once I figured out the polarity was reversed, now the lights on the throttle that attempt to indicate how much battery you have left now light up. The problem is that the engine never engages either via throttle or peddle assist. To complicate matters, it did tip over while I was working on it.
I have two theories...
1) I pooched the controller when I had the polarity reversed.
2) The brake cutoff is engaged improperly
Any suggestions on how to determine which of these (or any other possibilities) it might be?
Well... I ordered some parts from China and will be starting an adventure since I don't really know what I am doing.
I got a new controller, LCD meter, PAS sensor, brakes and throttle. Basically the only thing I won't have replaced is the hub motor. All for just under $100 with about half of that being shipping.
I hope everything works together, or I'll be throwing more money at it.
Anyone have experience doing anything similar? Wondering what gotchas to expect.
